Board index i2/i3 Technical discussion i2/i3 for Ford vehicles Racing Module
Racing Module
Post Thu Nov 12, 2015 2:52 pm
I have a 2012 F-150 with ecoboost. I purchased the Trinity 1000 and installed the 93 tune after I changed out my plugs and set them to .029. What a difference it made. I love it. I'm having a problem getting the "Racing" module to work. I go into it, select 0-60 then motion start and nothing happens. I also tried it on the tree with the same result. Any help would be appreciated. Thanks.
Post Thu Nov 12, 2015 3:12 pm
we're sorting this out currently.
561-908-0040x4
Post Mon Nov 16, 2015 9:15 am
Any progress?
Post Wed Nov 18, 2015 5:44 pm
Mike, are you still working on this?
Post Thu Nov 19, 2015 11:10 am
sorry, it got held up in engineering but is still being addressed.
561-908-0040x4
Post Tue Nov 24, 2015 10:48 am
Go to the logging menu and then hit restore default dashboards while plugged into the vehicle and key on. Should work then provided you are on the latest update. I tested it yesterday morning.
Insert Clever comment here...
Post Tue Nov 24, 2015 4:33 pm
I will try it out. Thanks.
Post Tue Dec 29, 2015 6:56 pm
Still not working. The drag tree worked once but won't work again. The motion start has not ever worked. My tool is 2.2.2.11 which appears to be the current version of the software. What should i do? Thanks.
Post Mon Jan 04, 2016 10:52 am
whats the version on the trinity under options/show information.
561-908-0040x4
Post Mon Jan 04, 2016 12:12 pm
I will look tonight and get back with you. Thanks.
Post Tue Jan 05, 2016 8:48 am
My Trinity version is v.1r13I
Post Mon Jan 11, 2016 9:02 am
Any progress?
Post Mon Jan 11, 2016 12:08 pm
so right now the drag tree never connects, even after restoring default layouts?
561-908-0040x4
Post Mon Jan 11, 2016 2:02 pm
I restored the default layouts several times and the drag tree worked once but the motion start has never worked. On a side note the one time the drag tree worked it did not stop when I reached the set speed of 60 MPH so I could not determine how many seconds lapsed.
Post Tue Jan 19, 2016 11:56 am
Any progress yet?
Next
Return to i2/i3 for Ford vehicles
