Board index i2/i3 Technical discussion i2/i3 for Ford vehicles 2012 F150 5.0 no throttle response
Post Wed Nov 18, 2015 4:21 pm
I have the i2 and installed the 87 octane tune this morning, went to drive the truck to work and did not have any throttle response truck would idle around 2000 rpm but would not change with throttle movement.
Post Thu Nov 19, 2015 11:10 am
did you load the tune through easy tune and disable speed limit there?
If so, please use the advanced menu to disable the limiter and it will work fine.
561-908-0040x4
Post Thu Nov 19, 2015 1:22 pm
Thanks mike worked perfect
Post Tue Nov 24, 2015 1:55 pm
Glad I got on this forum.
I was having the same issue with my 2015 F150 3.5 ecoboost.
Idles but pedal is dead when put back to stock tune no problem.
Post Tue Nov 24, 2015 3:49 pm
this is a different issue, we can provide a customtune to correct it for now, please post your backup here or in the thread specific to ths issue under general support.
561-908-0040x4
Return to i2/i3 for Ford vehicles
