Board index i2/i3 Technical discussion i2/i3 for Ford vehicles Intune 2 stuk in please wait screen
Post Sat Nov 28, 2015 1:23 pm
Plug it in and hit agree to disclaimer. Tune vehicle. Turn key on. Doesn't move past the Please wait screen
Using it on a 2009 Ford crown vic
Worked before. This problem started after I cleared a engine light code.
Updated the tool when I got it last month.
Post Sun Nov 29, 2015 11:42 am
No one has a response?
OK.
I'll call them tomorrow.
They should be open on Saturdays.
Just saying
Post Mon Nov 30, 2015 1:16 pm
can you post the info.xml file from the i2 drive lease?
561-908-0040x4
Post Mon Dec 21, 2015 12:02 pm
the file you requested Mike
Post Mon Dec 21, 2015 12:19 pm
also take note to the following issues (while the tuner did work)
The adjustable parameters do not work. tranny shift pressure is always stuck on hard no matter where i place the bar at in the tuner.
adjusting the shift points via RPMs doesn't work. car still shifts out at stock levels. we couldn't even get the car to shift higher with a custom tune.
example.
Stock 1st-2nd @ WOT 5500 rpms
Stock 2nd-3rd @WOT 5750 rpms
Tuner couldn't make the car shift at 5700 rpms from 1st-2nd @ WOT
also WOT fuel Curve. if adjusted in the tuner, the car will bog if the accelerator is pushed to the floor. it feels like instant limp mode like the Electronic Throttle Control Shuts down thrusting me forward in the seat.
Post Tue Dec 29, 2015 9:38 am
example.
Post your last tune written. If it wouldn't with a custom tune then the tuner is in fact doing it's job and it's something else, but I have to see what you're working with.
Insert Clever comment here...
Return to i2/i3 for Ford vehicles
