Board index i2/i3 Technical discussion i2/i3 for Ford vehicles Custom tunes not showing up?
Post Fri Feb 05, 2016 10:20 pm
I recently bought the Diablo I2 and got some custom tunes from BAMA and when I try to tune the car, it shows there's no custom tunes available when I have a 93 performance and a 93 race tune on the device itself. Is the folder incorrectly named or?
On the computer, it shows up as
i2(F:) > tunes > 93p.frg 93r.frg
Update:
I tried to put the tunes in the regular i2 folder and I end up getting an error.
Import Tune decode error: -1
I go to load them and the custom tune bar is dimmed out and I can't access them, is something named incorrectly?
XML doc is uploaded
Post Mon Feb 08, 2016 6:35 pm
I think we were emailing with you, I think you are all set now.
Let us know if you need anything else.
561-908-0040x4
Post Mon Feb 08, 2016 6:38 pm
Currently emailing now, not yet solved though. Hopefully soon.
Post Tue Feb 16, 2016 1:16 pm
I'm having the same problem. Custom tune is in "tunes" folder but custom tune section is greyed out on install screen
IVMOTORSPORTS.COM
Post Tue Feb 16, 2016 1:20 pm
custom tunes should not go in a folder, place them in the root of the i2 drive and the tool will import them from there ;)
561-908-0040x4
Post Wed Feb 24, 2016 11:03 pm
same here man i dont have them what should i do
Return to i2/i3 for Ford vehicles
