Board index i2/i3 Technical discussion i2/i3 for Ford vehicles PCM 0420/0430
PCM 0420/0430
Post Mon Mar 21, 2016 8:13 am
i recently bought the i2 tuner for my '13 mustang and it works great. i also bought bbk long tube and bbk x-pipe along with a a k&n typhoon air filter. should i adjust any of the parameters on the tool after putting the 100mm universal air/93 tune because the two codes i am getting is becoming annoying. i've inspected the header gaskets at the block to make sure there is no leak as well as where the x-pipe meets the end of the long tube.. any help is greatly appreciated.
Post Mon Mar 21, 2016 9:35 am
the 420 code and the 430 code are cat codes from your x pipe. you will need a custom tune to have the rear cat monitors disabled.
Post Mon Mar 21, 2016 10:12 am
how do i go about getting a custom tune with 5 star tuning?
Post Mon Mar 21, 2016 10:27 am
contact 5 Star Tuning..
Return to i2/i3 for Ford vehicles
