"This Vehicle isn't supported" error
I installed the 93 performance tune on my 06 f150 5.4 and it worked good the first time and went back to adjust the shift points and now it says that the vehicle isn't supported. What Now?
Re: "This Vehicle isn't supported" error
tech@diablosport.com
here it is I think.
your i-1000 simply needs to be connected to a PC and allowed to update.
ok yeah its is kind of old. I was looking for an update but where is it?
its an i2020 though. I originally bought it back in 2013 for my '13 GT mustang. I have a procharger on it now and just thought about using this on my f150 just today.
you need to run the updater from the intune Updater folder
Ok its updating. I will let you know if it doesn't work. Thanks!
Now it is saying that "The current firmware revision (1r03j) cannot be replaced by firmware package within Group_Update_6" is this a problem? Well I hit continue and it says Failed to install Group_update.itfg
I ran the update again and it worked! I think there was some interruptions during the first try my laptop is a POS. I will go see if it will work on my truck now.
Okay all is working well. My truck is a little less of a turd now. LOL!
