Tuner reading 91 octane tune when loading 93 with 2.7 pulley
When loading the 93 with 2.7 pulley on 2012 GT500 , 91 octane is displayed at the bottom of the screen. I've taken it back to stock and tried it several times but still shows 91 octane. I can't be sure if the correct tune has been loaded. Is this normal? The i2020 has been updated. No more updates available.
Re: Tuner reading 91 octane tune when loading 93 with 2.7 pu
gazza wrote:When loading the 93 with 2.7 pulley on 2012 GT500 , 91 octane is displayed at the bottom of the screen. I've taken it back to stock and tried it several times but still shows 91 octane. I can't be sure if the correct tune has been loaded. Is this normal? The i2020 has been updated. No more updates available.
this is more thank likely a display issue. it is probably loading the correct tune. if you can please load the tune then attach the last tune written and i'll double check
