hello my i2 will not recognize my truck anymore and have updated several times and says it is up to date
any help would be greatly appreciated
thanks, steve
i2 wont recognize vehicle
Re: i2 wont recognize vehicle
was the vehicle updated by a dealer?
what exactly happens when you try to tune it?
tech@diablosport.com
No it was not updated by a dealer.....everytime I plug the tuner in it ends up saying my vehicle is not supported and need to update but I keep updating and says it's up to date
Are you trying to tune a Ford here?
This device is a Dodge tool, it wont work on a Ford...
I am trying to tune a ford truck and have tuned it many times with this tuner how in the world did it become a dodge tuner when it's supposed to be a ford tuner??!!.
This is actually still my beta tester.....right before I got it in the mail I had a work injury and had to have surgery and couldn't do much of anything for quite a while and then when I could get back to driving and doing things I started using it and loved it and then around this past Christmas I put the stock tune back in and then when went back to retune it it said it wasn't supported anymore I updated several times with no success of fixing it
did you update it recently with ignition??
please update it again now then try it again and it should work fine.
I have updated many times with ignition but I will try again later tonight when I get home will let you know what happens
Updated again and works fine now thank you very much I have another question will this accept custom tunes and if so how do I get one on there and how can I use the tool to retrieve my pcm strategy code ?
