Board index i2/i3 Technical discussion i2/i3 for Ford vehicles I2 2018 F150 5.0
I2 2018 F150 5.0
Post Wed Sep 12, 2018 9:39 am
save this file to the i2 drive and let it import the file then you can tune your truck.
561-908-0040x4
Post Wed Sep 12, 2018 12:44 pm
Works great, thanks for your help
Post Fri Sep 14, 2018 12:36 pm
Mikel, I am getting DTC P0500 "Vehicle Speed Sensor" Error with this tune. Please Help.
Post Fri Sep 14, 2018 2:53 pm
ok, did you make any adjustments to the tune when you loaded it?
Will you please post the info.xml file from the tool as well as the files from the tunes folder on the i2 drive so I can check it out?
561-908-0040x4
Post Fri Sep 14, 2018 3:23 pm
[quote="mikel"]ok, did you make any adjustments to the tune when you loaded it?
No adjustments, the only thing the tune would allow me to change was axle and tires. Nothing else. Files attached.
Post Mon Sep 17, 2018 7:58 am
OK, so, did you adjust the axle or tire setting?
The reason i ask is the code you describe sounds like one that may come up if that stuff is adjusted incorrectly.
Do you have stock gears in the truck?
Taller tires?
561-908-0040x4
Post Mon Sep 17, 2018 9:14 am
Taller tires?
"NO ADJUSTMENTS MADE to any parameters". Vehicle is STOCK except Roush Air Intake.
Post Wed Jan 23, 2019 1:06 pm
corrected database is here.
561-908-0040x4
Previous
Return to i2/i3 for Ford vehicles
cron
