Does anyone know if I can use both the In tunes i2 with the JMS BoostMAX on my 2014 ford explorer Sport?
Kenny
JMS BoostMAX Ford 3.5L EcoBoost
Re: JMS BoostMAX Ford 3.5L EcoBoost
assuming that is a throttle controller, sure.
tech@diablosport.com
Mike,
I probably wasn't as specific as I needed to be on this question, sorry. JMS has two particular items and i want to be sure that you understood what I was asking or you know the difference between the two, which i may not. Your reply to my original question referred to as long as it was a throttle controller. Which is the way I understand it does, because it is connected to the MAP sensor, TIP sensor and the and finally to the Pedal Position Sensor
They produce a item called BoostMax and another called PedalMax. I purchased the BoostMax. Within the JMS published instructions it states not to run with a tuner other than their own (marketing ploy?)
If i can install is there another tune that I would need to get from you?
Thank you for your time
Kenny
Kenny
Kenny,
You CANNOT run the BoostMax with any pre-loaded tune. You will need a custom tune specifically for the BoostMax to prevent overboosting and potential severe issues. You can use the CMR dealer locator to find a tuner near you or a mail order tuner like us.
http://www.tpctuning.com
Or try the canned tunes, my guess is they work as well or better
Mike,
So what you are saying is that I could try the "canned" tunes that are in the I2 Tuner?
Kenny
Kenny
Im suggesting you try them as opposed tot he boost max device
