Board index i2/i3 Technical discussion i2/i3 for Ford vehicles INTUNE I3 FOR FORD PLATINUM - 8145
Post Wed Oct 03, 2018 1:55 pm
Mike under Features for the subject tuner can we please get them updated. It looks like half of the Features that are there, are for a different product and not the i3?
Post Wed Oct 03, 2018 3:30 pm
got a screenshot maybe?
561-908-0040x4
Post Wed Oct 03, 2018 3:55 pm
These are the Features that are posted under the i3?
Features Support
All applications supported under one part number. Never worry about getting the right one; If we support, it works
The Trinity comes preloaded with canned tunes. We spend hundreds of hours developing tunes for your vehicle for maximum safe power and torque for your application.
Full color touch-screen. Follow the instructions and use the color touch screen to easily program your vehicle.
Customizable gauge layouts. Save hundreds of dollars on aftermarket gauges.
Programmable LED lights. Turn the lights into a shift light or a warning light.
5 volt input. The input allows you to hook up several aftermarket accessories like wide band O2 sensors.
Holds up to 5 custom tunes. Use our worldwide network of CMR tuners to step above our canned tunes.
93 Octane Performance Tune: 70HP 100TQ
91 Octane Performance Tune: 65HP 90TQ
87 Octane Performance Tune: 50HP 70TQ
Towing Tune 50HP 70TQ
Touch Screen - Y
Data Logging - Y
Check Clear DTCs - Y
5 Volt Data Logging Inputs - Y
Accepts Custom Tunes from CMR - Y
Calibrate Speedometer for Gear Ratio - Y
Calibrate Speedo for Tire Size - Y
Cooling Fan Control - Y
Throttle Booster - Y
Fuel Rich/Lean Adjustment - Y
Spark Timing Advance/Retard - Y
Idle RPM - Y
Top Speed Limiter - Y
Rev Limiter - Y
Shift Points - Y
Global Timing Adjustment - Y
Intake Cam Adjustment vs. RPM - Y
Exhaust Cam Adjustment vs. RPM - Y
Post Thu Oct 04, 2018 3:01 pm
thanks, which vehicle are you configuring and what options are you not seeing in the device?
561-908-0040x4
Post Thu Oct 04, 2018 3:51 pm
I am trying to configure my 2018 F150 Lariat 3.5 EB which is the subject on the other thread. Not seeing any options for for this vehicle. Under Modify Parameter then Select Parameter Control Unit to Modify, there was nothing there it is a blank screen
Post Wed Oct 17, 2018 7:19 pm
Mike are they updating the features for the i3 Platinum for the ford, half of what is posted under features does not belong to this unit?
Post Mon Oct 29, 2018 4:15 pm
This is being addressed and will be fixed in a future update soon.
561-908-0040x4
Return to i2/i3 for Ford vehicles
