Board index i2/i3 Technical discussion i2/i3 for Ford vehicles I3 Platinum will not import CMR tunes
Post Wed Nov 28, 2018 1:14 pm
Having trouble importing CMR tunes into a I3 P . Was perviously working and cant figure out the problem now.
Just trying to load a slightly modified tune attached to get things working properly.
will the file import and not show up, or simply will not import at all?
Can you post the backup and info files as well please?
561-908-0040x4
Mike I found out the issue I was having importing files to tool. I looked into the tune file I had been trying to load and noticed the VIN number was not in the end WHITE message/ Notes box when saving. Put the vin in all CAPS into that box and issue solved. I am now having a tuning issue on this vehicle. for some reason the Cold start enrichment is overcompensating and flooding out on sub 40 degree mornings. in my location it was 55-60 degrees and it was a bit grumpy but started. I have played with different settings with no prevail. Any Info on this one? Attached is most recent tune file. :punisher:
Post Wed Dec 05, 2018 11:13 am
Thats above my pay grade ;)
Please shoot the file and a log over to cmrtech@diablosport.com so the calibration team can check it out.
561-908-0040x4
Return to i2/i3 for Ford vehicles
