Board index i2/i3 Technical discussion i2/i3 for Ford vehicles i3 Update Agent Error
Post Sun Feb 10, 2019 11:17 am
While trying to update my i3 with the Update Agent, it successfully downloaded 4/11, 5/11, 6/11, 7/11 and when downloading 8/11 it stopped and indicated " unable to read data from transport connection: an existing connection was forcibly closed by the remote host.
-> an existing connection was forcibly closed by the remote host
UPDATE:
I used the wifi to try and update the i3, it downloaded all the updates and installed them successfully. Connected to the Update Agent and it reported my i3 is up to date. So I believe it is the Update Agent that is not working properly?
Post Mon Feb 11, 2019 8:56 am
thanks, well check this out.
561-908-0040x4
Post Sat Feb 16, 2019 11:41 am
Mike did they find anything out why the update agent wouldn't complete the update?
Post Fri Feb 22, 2019 12:59 pm
Havent hear dback, have you tried it again since?
The tool is working fine correct?
In all honesty, if thats the case, theres no need to update ;)
561-908-0040x4
Post Sun Mar 24, 2019 11:26 pm
Crappy answer Mikel. I experienced the same problem. If the i3 Platinum is up to date, then why isn't the update "sticking"? My i3 wants to update each time as well.
I am brand new to tuning, so perhaps I am missing something.
2000 F350 Crew Cab
7.3L Power Stroke
Post Wed Mar 27, 2019 7:56 am
thats a bug, where it keeps delivering the same update. It is something our team is looking into.
if you update it once and it says its done, then its done, no need to relaunch the software and do it again, its just reloading the same files.
561-908-0040x4
Return to i2/i3 for Ford vehicles
