Board index i2/i3 Technical discussion i2/i3 for Ford vehicles Throttle jerking on F150? No power at high rpm
I have this problem with all of the tunes. Right now I'm using the MPG boost tune. Between 4500rpm and 5000rpm the power fades and feels like it's surging. I've had this problem for a while, happens under load almost every time from 2nd gear to third.
This does not happen with the stock tune.
The log shows the throttle angle bouncing around...not sure why. Shouldn't it be smooth?
I will post a log.
Thank you.
what year and engine in this truck?
561-908-0040x4
2012 Ford F150 3.5L Ecoboost
please post a copy of the info.xml file as well as the last tune written from the tunes folder so we can look into this.
561-908-0040x4
Return to i2/i3 for Ford vehicles
