So, my Intune issues continue. I2 on KWC4 strategy.
Whenever I try to make cam timing changes with "Modify parameters", when hitting "apply tune" the I2020 gives me the message in the title and does not flash the changes to the car.
I do have a tech support ticket open, but maybe there is a simple/quick solution..
Here is the xml
Cam timing adjustments are what is causing this error. All other adjustable parameters seem to work.
Unexpected error has occourred, generating log....
Re: Unexpected error has occourred, generating log....
can you post the files from the folder called runtime?
tech@diablosport.com
Here you go Mike,
These were the 3 attempts I made over the weekend. The last one worked without issues, but I had to reset all changes in the tuner. Then I was able to make fueling and timing changes.
Ps:Still would like to have all 8 monitors if you could figure out why I lose the catalyst monitor.
what do you mean by lose the catalyst monitor?
After tuning with the I2020 catalyst monitor becomes "not available". I cannot pass emission test with any obd2 monitors disabled.mikel wrote:what do you mean by lose the catalyst monitor?
