Board index i2/i3 Technical discussion i2/i3 for GM vehicles 08 Chevy 5.3 update over wifi.
Post Fri Jul 21, 2017 7:08 pm
I've went thru the process like 6 times and it still says updates are available has anybody else ever had this happen before?
Post Sat Jul 22, 2017 5:30 pm
Use the ignition to update the it on your pc.
Post Tue Jul 25, 2017 11:16 am
please post the info.xml file fro the i2 drive so I can check it out.
561-908-0040x4
Post Thu Jul 27, 2017 10:08 pm
Not sure how to do that. I don't have a computer hence the reason I got the wifi connection thing.
Post Fri Jul 28, 2017 12:36 pm
well, then you won't be able to get the files needed.. because you have to connect it to a computer to get copies of the files.
Post Tue Sep 12, 2017 5:57 pm
think this is the file
Post Wed Sep 13, 2017 8:33 am
once you update on a pc one time, it will update the wifi updater and allow it to get the latest files, but it seems your device is working fine, no need to update it really.
561-908-0040x4
Return to i2/i3 for GM vehicles
cron
