Board index i2/i3 Technical discussion i2/i3 for GM vehicles AFM/DOD disable
AFM/DOD disable
Post Thu Feb 13, 2020 9:24 am
I just installed my first tune on my 18 Silverado. Was able to switch my tire size and installed the 87 tune with firm shift. I didn’t have the option to modify parameters to disable DOD (it wasn’t selectable. I used the easy tune option). Can I just plug it in and overwrite the tune, or should I restore to stock and start over again? Thanks for the direction
Post Fri Feb 14, 2020 10:13 am
Go back in and select advanced tune, then go to modify parameters
Select AFM, set it to off and save the change then back out and select apply tune.
561-908-0040x4
Return to i2/i3 for GM vehicles
