jack haughton wrote:
can the program be loaded on the tow haul switch and leave the factory tune on the main setting? thanks.
No... that's not how the tow/haul button works... You'd just use the tow/haul button on the dash/lever like you normally would. That just tells the transmission to use different shifting settings, that's all it does. The engine tune does not and can not change at all when you press that button, only the tranny shift points change, that's all it does...
