When tuning with advanced options and adjusting parameters, does the logic work off the "stock" numbers? Say I adjust shift point to a "plus 7". I'm assuming it's the original value plus 7? Does the logic always revert to the stock numbers? Say I have a tune already installed with a shift point of 4 and the next tune I increase to 7. My new shift point is still 7, correct? It wouldn't be the 4 plus 7, to equal 11? Again, I'm assuming the logic always reverts back to a stock number?
Thanks.
Tune logic?
Re: Tune logic?
Lyman24 wrote:When tuning with advanced options and adjusting parameters, does the logic work off the "stock" numbers? Say I adjust shift point to a "plus 7". I'm assuming it's the original value plus 7? Does the logic always revert to the stock numbers? Say I have a tune already installed with a shift point of 4 and the next tune I increase to 7. My new shift point is still 7, correct? It wouldn't be the 4 plus 7, to equal 11? Again, I'm assuming the logic always reverts back to a stock number?
Thanks.
yes you are correct. what ever you set it to, it stays there. if you set to 4 it stays at 4 untill you go in and raise it up or down. so if you raise to 7 it will now be 7
