03 tahoe I2 wont change gear ratio
Hello every one, im new here. Just bought a diablo i2 for my wifes 03 tahoe that had the gears changed to 4.56's and 33" tires. Bought the diablo because it said that you can change those two items, but im only seeing where you can change the tire size , NOT the gear ratio. What am i missing?
TIA
lost and hopeless
TIA
lost and hopeless
Re: 03 tahoe I2 wont change gear ratio
its a bug on our end, please post the files from the tunes folder after you install the tune and let us know what the stock gears were and what the new gears are and we'll correct it for you.
tech@diablosport.com
sweet thanks!
2003 chevy tahoe
5.3 v8 flex fuel
stock gears 3.73
new gears 4.56 with 33" tires
2003 chevy tahoe
5.3 v8 flex fuel
stock gears 3.73
need the backup file from the tunes folder as well please.
ok sorry
new file attached, save to i2 drive, let tool import it then load to the vehicle.
Sweet! Loaded and it works just fine! Thank you again
Hello,
I bought the i2 for my 2000 Chevy Silverado so that I can correct my gear ratio and tire size along with performance upgrades. I do not have the ability to change the gear ratio In any way. The only place I see the question to change the ratio is in easy tune, which I don't want to do but regardless, when I hit yes to change it, it will not give me an option to do so. can someone help me please? I would like to have the ability to change it in the different octane tunes and the modify tune menu also.
5.3 v8
stock gears 3.42
new gears 4.10 with 35" tires
Jason
5.3 v8
stock gears 3.42
Jason
here you go.
Thank you sir.
I have a 99 Chevy Silverado that has the gear ratio changed from 3.73 to 4.56 please help. I could not find the option to change the gear ratio myself. If you could just make a tune with that it would be great! Thank you!
did you already email us these files?khawk32 wrote:I have a 99 Chevy Silverado that has the gear ratio changed from 3.73 to 4.56 please help. I could not find the option to change the gear ratio myself. If you could just make a tune with that it would be great! Thank you!
No, is that what you'd like?
No need, heres the new tune.khawk32 wrote:No, is that what you'd like?
Same story here....I see the option to change the gear ratio, but I get an error when selecting that option.
2000 GMC Sierra 1500 4WD 4.8L
33.25" Tires (measured size)
Ignition Updater reports I'm on the latest software version
Need to change gearing from 3.73 to 4.56 as well, in addition to correcting for 35" tires (33.25" measured size on-vehicle), all for a 93 Octane tune.
Should I use the files previously posted above? My files are attached.
Thank you!
Thank you!
