08 Chevy 5.3 update over wifi.
I've went thru the process like 6 times and it still says updates are available has anybody else ever had this happen before?
Re: 08 Chevy 5.3 update over wifi.
Use the ignition to update the it on your pc.
please post the info.xml file fro the i2 drive so I can check it out.Countryboy739 wrote:I've went thru the process like 6 times and it still says updates are available has anybody else ever had this happen before?
tech@diablosport.com
Not sure how to do that. I don't have a computer hence the reason I got the wifi connection thing.
well, then you won't be able to get the files needed.. because you have to connect it to a computer to get copies of the files.
think this is the file
once you update on a pc one time, it will update the wifi updater and allow it to get the latest files, but it seems your device is working fine, no need to update it really.
