2016 Camaro SS V8 European version support
Hello,
I have a 2016 Chevrolet Camaro SS, 8 speed, with magnetic ride and NPP (European version).
When I try to upload a tune, I get a message saying unsupported PCM. Does the i2030 support the European version 2016 Camaro SS V8?
Here is the latest info.XML file from the I2 drive.
Re: 2016 Camaro SS V8 European version support
the i2 needs to be updated, please install the ignition software and let it update the device then try again.
if it still says unsupported, let it read out the file(s) and then email them to us or post them here.
tech@diablosport.com
Thanks for your answer!
Here is the saved PCM backup file.
to confirm, this is after updating the device?
Sorry for the late reply. After all the updates, I still get a message saying unsupported PCM.
Here are the newest, updated info.xml and PCM backup files:
did you read the file before updating the device?
Can you try restoring the stock tune to the vehicle then read anther copy of the backup file and post it here please?
Actually, save this to the i2 drive, let the device import it then you can tune the car.mikel wrote:did you read the file before updating the device?
Everything is working fine now, thanks for the top notch customer service!
At last I had the time to take my car (otherwise stock) to the track. Car ran on 100 Octane RON fuel, and was slower with the tune installed, by 0.1 sec and 2-2,5 miles, multiple runs, multiple tunes (91 octane, 93 octane, Diablosport tune). After resetting to factory tune, results were back to normal. Any ideas what the problem might be? Tomorrow I will try again, shall I take some logs, can that be analyzed?
please use the device to record a datalog at WOT so we can see whats happening.
Thanks. Due to the weather I was not able to do it, as soon as it permits, I will do some WOT runs and post the log.mikel wrote:please use the device to record a datalog at WOT so we can see whats happening.
