Cat Delete tune
- sinistersf
Cat Delete tune
Is there a cat delete option in the standard tunes that come with the device?
"It's better to burn out, than to fade away"
Re: Cat Delete tune
no.. you can not disable any emissions/trouble codes via the tool itself... it's against EPA rules/laws....
- sinistersf
Re: Cat Delete tune
can you get a custom tune for off road use?
Re: Cat Delete tune
yes, only way to disable the necessary codes and related items, get fueling/airflow/timing adjusted correctly, etc. would be via a custom tune... as long as you have the inTune i2 i2030, or the inTune i3 8245 Platinum version tools...
www.diablewtune.com -- and you can also email me directly at -- diablo DOT help AT gmail DOT com -- with the year, model, engine, of your GM vehicle, all of the mods done to it, what octane gas you use, which version/model diablo tool you have, etc.. and I can send you a loooong email with info about the custom tuning, the process, etc.
Thanks!
-Lew
Thanks!
-Lew
