tune question
tune question
I have a 2005 gto,I have been changing my tunes to try to get my wot dialed in. I have a wideband, I have my slope at -4 and my ltft is between 0 and -3. So i hit it WOT and my wideband says 14.4! wow super lean. I am on the 91 tune. I have CAI, longtubes, and a cat back with no cats. So i add 10% PE in both fields and get 11.4. I then change it to 8% and it goes to 11.9. So i do the math and figure i need 4% to be at around 12.6-12.8. So i set it and dang it goes to 14.0. I pull over and put it to 6% now wideband says 13.7 what the heck is going on? Why cant i get this dialed in? Does it have something to do with all the emissions parameters not being set? Maybe the fuel trims are not set yet and that is effecting PE? Should i drive for a day or so before i can expect a change in PE? Am i at my limits of this tuner and need to to a full tuning suite where i can play with the MAF?
Re: tune question
Are my negative ltft somehow effecting my PE. Pulling fuel instead of just running off of the PE.
Re: tune question
no.. negative trims do not affect PE at all.. . only if they are positive, then they add that percentage of fuel to the PE...
you need to modify the WOT/PE fueling table and add fuel if your wideband is correct...
