gto supercharger question
Hello all. i have a ls2 gto. I have a intune I3 i use to tune it now. I plan on putting a torqstorm blower on it. I will be keeping the stock cam but adding 60lb deka injectors. I already have 1 7/8 long tubes, ported intake and throttle body, 3200 stall. I plan on 8lbs of boost. Can i tune it with the I3?
Re: gto supercharger question
you'd need to take that setup to a shop to get tuned safely on a dyno... if the shop has diablosport's CMR tuning software, then can create a custom tune for your intune... if not, then they would be tuning it with hptuners or efilive software and you would not be able to use the intune...
What is the max timing I can pull with the i3? I want to run 13 degrees max. If I cant pull enough I guess hp tuners it must be.
