Does applying a tune change your Driver Information Center mileage accuracy? Mine seems to be 2 MPG off from hand calc. I would take the tune off and give it a look see but I love having it off too much.
Thank you.
MPG on DIC
Re: MPG on DIC
yes.. it can take a while for that to be correct again, as a lot of things get reset whenever a tune is installed (or when battery is disconnected)
Re: MPG on DIC
06MonteSS wrote:yes.. it can take a while for that to be correct again, as a lot of things get reset whenever a tune is installed (or when battery is disconnected)
Well son-a-mun-gun! I keep my intune as up to date as possible as such I’ll reflash to stock then re-tune after every update. So it looks like I’m not giving it enough time to fix itself.
I’ll not reflash for a few tanks or so and update.
Thanks Monte
Re: MPG on DIC
you don't have to restore original backup and then retune the truck again every time bud, heh... there's no changes to the tunes on a tool update... no need to keep doing that...
Plus, Every time you install a tune (or disconnect the battery), all of the learned items like idle, airflow, fueling/fuel trims, emissions readiness tests, transmission shifting adaptives, etc. all get erased/reset... It takes several days/150+ miles to be put on for everything to be relearned by the ECM/TCM and settle back in again....
so stop doing that, heh...
Re: MPG on DIC
Thank you for the lessons sir. I’ve run the intune on my 15 Silverado, 15 Sierra, and now the 18 Sierra and had no idea. You only know what you know.06MonteSS wrote:you don't have to restore original backup and then retune the truck again every time bud, heh... there's no changes to the tunes on a tool update... no need to keep doing that...
Re: MPG on DIC
Good day sir. It's been some time since I've left hands off of my diablo intune to see if the MPG on the DIC would match up with hand calculations. It is still 2 mpg's off. This truck is bone stock aside from new K02's I bought a couple of weeks ago. Stock size tires.06MonteSS wrote:you don't have to restore original backup and then retune the truck again every time bud, heh... there's no changes to the tunes on a tool update... no need to keep doing that...
Thank you.
