Board index Predator 2 Support Predator 2 for GM predator 2 7202
predator 2 7202
Discuss Predator 2 for GM vehicles.
Post Sat Apr 20, 2019 12:11 pm
bought a predator 2 for my 2003 silverado 1500 hd i updated it out of the box hooked up to truck and chose the 87 performance tune for 1-2 &2-3 shift points i used diablo value and 3-4 i used stock. on all shift pressure choices i used stock plus 6psi and disabled torque management. i left all other parameters stock. all my shifts are perfect and the extra power is great but now my torque converter locks at 60mph instead of 50mph in overdrive i was curious if this is normal or not i would like it to lock up at 50mph like factory if all possible thank you!
Post Tue Apr 23, 2019 6:58 am
i wouldnt expect that to be changed. Can you provide the device serial number?
561-908-0040x4
Post Mon Apr 29, 2019 1:11 pm
Serial number is 201323295
Post Fri May 03, 2019 11:28 am
Any ideas?
Post Wed May 08, 2019 11:06 am
Ive asked someone to verify the tune changes for us.
561-908-0040x4
Post Tue May 14, 2019 4:36 pm
Ok thanks
Post Thu Mar 12, 2020 4:05 pm
Kun
Hi Guys,
I recently installed a K&N cold air intake and I'm wondering if there is any settings that needs to be done on my predator 2 to get more power from it?
I didn't find any option in the tune menu, but I think I saw the cold air intake specs in some place that I cannot recall.
Do you have any advice ?
Post Fri Mar 13, 2020 9:23 am
Kun wrote:
Hi Guys,
what vehicle is it?
Most GMs do not require a tune for a CAI.
561-908-0040x4
Post Sat Mar 14, 2020 12:22 pm
Kun
Hi Mike, thank you for your reply.
An Escalade 2013. So, from what I see in the options menu I only have air intake temp whcih I really don't know how or what can I do with it.
But maybe there is another tun from anotheDiablo that can be used to get nore gain from th cold air intake, or it is what it is?
Just wondering as , well diablo 93 tune is great!! and besides a good grawling sound with the cold air intake, I don't really see much difference.
Return to Predator 2 for GM
