Board index Trinity 2 T2 for Dodge/Chrysler/Jeep/Ram Ram 1500 E fan swap.
Post Wed Jun 13, 2018 11:12 am
I am about to do an efan swap and delete the clutch fan on my 16 ram 1500. My question is what temp should I set the fan to cut on at with the stock thermostat. I know factory is 222 degrees but that is just to cut on the small a/c fan to help the clutch fan.
Post Fri Jun 15, 2018 1:49 pm
you wont have control of it I wouldn't imagine.
Post your backup and I can look at hos the file is set up to see if the efan can be enabled.
561-908-0040x4
Post Sat Jun 23, 2018 10:00 am
It can be done through my custom tune but should I be able to control it with the tuner? I have an ECT fan option. Also I do not have disable traction under quick adjust like I use to have. I updated it and now its gone. I included the backup for the fan adjust and will also post the info.xml to see where my quick adjust options. Thanks in advance.
Post Mon Jun 25, 2018 8:30 am
you'll want to post the last tune written so I can edit that file.
561-908-0040x4
Post Mon Jun 25, 2018 9:55 am
Is that to adjust the fan or the traction? They seem to be able to control the fan and the traction via custom tune. I just wanted the traction disable under quick adjust again so when I cycle the key it is enabled again. Is that possible? They have the fan set perfect now via my custom tune.
Post Mon Jun 25, 2018 10:19 am
I'll need to look into the TC disable, nothing has changed there so it should still be there.
561-908-0040x4
Post Mon Jun 25, 2018 10:25 am
Not sure what the deal is it only shows tires under quick adjust. I’m hoping I can get it back soon. Kinda main reason I got it. All was good until I updated to 8 speed support. Initially it did it on my t1000 and carried over to the t2 when I switched to it.
Post Mon Jun 25, 2018 12:37 pm
ok here is the last tunes written. Currently in the truck.
Return to T2 for Dodge/Chrysler/Jeep/Ram
