constant loop on t2
constant loop on t2
This is really getting bad I cant drive my jeep. I try to update my tune. I get new tune the tuner goes into a loop/ First it says there are control units in this vehicle that are not supported continue to update over wifi if you say continue it goes for a few minutes and it finds updates and asks would you like to install you say yes it installs update then when you complete the update it says press continue to restore your vehicles factory data your choices are cancel or continue. Once complete it goes to the same thing again. Again I cant drive my Jeep with the factory tune I need to install my custom tune Please help
Re: constant loop on t2
please post the current info.xml file from the T2 drive so we can check it out.
tech@diablosport.com
Re: constant loop on t2 error code E0101
I contacted tech support and we fixed the problem only to create another. Here is what happened. I got stuck in the loop needs update downloading updates saves file needs update again. When all said and done several loops about 6 times. I called and was told when it says it needs the update pull the power and plug into the laptop and it will fix it. NOPE. Called again and said send me file and we will update sent file added new file NOPE! Called back it was after five so I emailed back and forth until he finally asked me for a set of numbers and than he gave me a password and it reset the unit to new and bam it worked (sort of) it did not go into the loop anymore but it errored out when loading. Loaded again and it loaded program only to have it say the TCM is not communicating U0101 code which wont clear. check engine light, trans over temp, service 4 wheel drive system light around all PRND indicators Trans in Limp Mode wont shift out of first and engine limited to 2800RPM and no AutoStart. LOTS OF CRAP!!! Now I call my tuner Jerseyboy Has never heard of it must be a loose wire. for over a week I check power to TCM check all connectors did a hard reset and nothing I shot wires check power check ground nothing I call your tech for advise asked them with the history is there any way the programmer could disable or error out the TCM. Said no way.it only loads to the PCM. I contact my engine guys Skip and Nat at Demon performance and they haven't heard of anything like it. Nate called me a few days later and told me they have another client that has the same issue. I called him and lord and behold he had the exact lights and the same issues after having the same tuner issue the programmer looping which you can verify by his phone number. He also had to call you and reset his tool and after it loaded the lights and problems are there. BAM he has the same issues he too called your tech back and was told no way it can be the Tuner. He was lucky enough and has a friend that also has a jeep SRT8 and they just pulled the TCM out of his and replaced it with his friends and it all worked no problems. He ordered a TCM and he is fixed. I ordered another TCM and got it install and no more problems. So the Moral is after programing getting stuck in the loop error on writing program it somehow locks the TCM. I welcome any explanation and here is the biggest issue I need to update the program and it is starting the loop again with Devise is not supported needs to update. What do you want me to do now?
