Leave the i2 plugged in?
I'm going to have time tomorrow to play around with my i2 tuner. After the tune is installed, do I leave the unit plugged in or can I remove it from the ALDL connector?
Re: Leave the i2 plugged in?
no it does not have to stay connected.. you only have to connect it when you are installing a tune or when recording a data log.. after you do a tune install, you can disconnect it.
