2018 Chevy Silverado 5.3L V8
New to the scene so bare with me. I purchased a T2 for my 2018 Chevy Silverado with the 5.3L V8. I plugged it in and tried to choose the 87 octane tune and the MPG boost tune and neither worked. I talked to customer service and all he said was I needed to update it. Then I called back and he said I can choose from any tune I want to install and I told him I had no idea what to install. I’m trying to get a performance tune, MPG boost tune, and towing tune. I have larger tires and a S&B intake are the only mods. Can someone please give me the tunes or links or whatever I need to make my T2 work!
Re: 2018 Chevy Silverado 5.3L V8
what do you mean when you say neither one worked?
tech@diablosport.com
Yep, normal.. 2017/2018/2019 vehicles require a special unlock sequence... so what will happen is, when you go to install a tune the first time, the tool will give you a message that "one or more controllers can not be tuned - Contacting powertech for vehicle unlock... you will be notified within 1-2 days" - or something similar to that effect.. so then in 1-2 days (usually within an hour though) you should receive an email (if you registered your tool on diablo's site) that your update is ready.. so then you'd run the Ignition Updater on the tool again, and it will update the tool with the unlock code for your ECM, and then you'd be able to tune the vehicle.
And there is no specific towing tune man.. not necessary.. you'd just install the 87 octane tune for 87/89 octane gas, or the Diablo Tune for 91/93 octane gas.. and when towing, you'd just use the tow/haul button on your dash like you normally would... that just tells the tranny to use different shifting settings, that's all it does.. there's no "towing" adjustments for the engine tune needed...
