2005 f-150 wrote:
yes that is correct the tunes are loading but there is no change in anything. for example i have the jlt 87 tune install before i installed it i made changes for example i adjusted the idle rpm all the way up to 1200 both in idle as well drive and it still idles at 600 in neutral and around 530 in drive. i have also made other adjustments such as the transmission shift points and the transmission is still shifting at the factory shift. so i dont know if there are some files missing in this tuner or what the situation is but i know that nothing is working when the tunes are installed. any help would be greatly appreciated. if need be i will gladly mail this back to you all so that you can take a look at it for me. Thank you and i do appreciate it.
ok,device is current.
Not sure what may be happening here.
Can you post the backup file and last tune written files from the device here please?
Also let me know specifically what changes you made when you loaded the tune?
