Board index Trinity 2 T2 for Ford tuner shutting down
tuner shutting down
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
Post Mon Nov 19, 2018 7:49 pm
F-150 2015 3.5l eco boost. My tuner shuts down for no apparent reason on a regular basis. I have to stop truck and then restart usually get the gages working again. This happens in all tunes and even when using factory tune.
Post Tue Nov 20, 2018 12:23 pm
So you can just be driving along and monitoring gauges then it shuts off, or freezes up?
561-908-0040x4
Post Tue Nov 20, 2018 7:02 pm
yes it just stops and the only way to start to turn truck off, open door and then restart.
Post Tue Nov 20, 2018 7:04 pm
I would say it freezes up because the display is still on just the gauges are not working.
Post Mon Nov 26, 2018 10:02 am
Can you post the contents of the runtime folder from the t2 drive as well as the info.xml file from the t2 drive?
561-908-0040x4
Return to T2 for Ford
cron
