Board index Trinity 2 T2 for Ford Updates
Updates
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
Post Sun Feb 16, 2020 11:28 pm
So I have, I believe the 9245. I use it on my 15 yukon and currently as a monitor in my 18 raptor.
I have not installed the program yet.
My question is , everytime there is an update for the programmer, do I have to unload the program from both vehicles, update, then reload? Or do the software updates not affect what is loaded?
Is there a way to check if the updates affect the vehicles one has, before going through the effort?
Also I posed a question in the MX forum about changing to Fahrenheit. My ECT seems to be stuck on Celsius. Tried everything I can find. Its on Imperial.
Post Mon Feb 17, 2020 11:21 am
No need to update it constantly.
Its not common for any changes to be made to the tunes unless they are not functioning properly.
We're looking into the unit conversion issue.
561-908-0040x4
Post Mon Feb 17, 2020 1:00 pm
Awesome, thank you
So there is an issue? Its not me? Yet..
Post Mon Feb 24, 2020 5:45 pm
Hey Mike,
Any update on the temp units?
Post Tue Feb 25, 2020 5:22 pm
Not just yet unfortunately.
561-908-0040x4
Post Wed Feb 26, 2020 11:35 am
Bummer.
Hey Mike, on my 18 raptor. The tune shows engine tuning options, but doesn’t say anything about the trans changes.
No firm or stock option?
Also it does not allow for throttle sensitivity/ adjustment?
Post Wed Feb 26, 2020 12:57 pm
Orrank wrote:
Bummer.
There is trans tuning, but i think its part of the ECM file, all in one.
Post the info.xml file from the device and I can confirm.
561-908-0040x4
Post Wed Feb 26, 2020 5:11 pm
And how does one do that? By was of the laptop or take a screenshot of something with my phone?
Post Wed Feb 26, 2020 7:28 pm
Also, ive tried both the switch positions for auto start/stop off/on. Neither disables the function
Post Thu Feb 27, 2020 11:25 am
connect the device using usb cable and attach the file from the t2 drive here.
Load the tune with start stop disable and then post the files from the tunes folder on the t2 drive as well or update it so i can see the tunes.
561-908-0040x4
Post Mon Mar 09, 2020 10:48 am
Hey Mike,
Got to play with it more.. wanted to update you.
C-F issue. I changed the gauge to the ECT gauge from the cooling menu. It went to F. For some reason the default loaded one from the Temperature menu was stuck on C. But works for me now.
Start stop, I backed the tune out and reloaded it. Works fine now. Unsure what happened the first time.
I still have to pull the Info file, to verify if any trans tuning is part of the package. Doesn’t seem any different.
Do you happen to know why there is no throttle booster on this vehicle? Other tuners have it, and yall include on other cars. Seems like a missing feature.
Thanks for the help
Post Mon Mar 09, 2020 11:22 am
throttle booster is specific to 14+ GM and most DCX applications, Ford has never offered a similar table to allow for similar adjustment.
561-908-0040x4
Return to T2 for Ford
