updates
updates
I would like to be able to check what update version is current "without" removing my Trinity from my truck and running the DSdownloader to see if something comes through. As I've noticed in the past, sometimes, this site is so busy that the downloads won't start. Using the DSdownloader I can't be sure if there is no update or I just need to call back later. Also, when do you release new updates? If I knew when to check, I wouldn't be checking several times per day.
Re: updates
well, for starters, there is never a need to check multiple times a day.
If your tool works now, no need to update at all, as most of the updates are simply to add support for new calibrations.
if you go to the trinity d/l page,. and type in your serial number, it shows you the current versions, and you can compare that to whats in the tool.
tech@diablosport.com
