Board index (Legacy) Predator Technical Discussion Predator Ford Gas My speedometer is now 10% off, but no tire size option?
After installing a custom tune (all I changed was the speed limiter and some shift firmness), my speedometer now reads 10% too low. (60 at 66) It seems like the Predator has maybe overwritten the tire size or axle ratio settings already in the vehicle.
But the Predator doesn't show me the "tire size" or "axle ratio" settings in the custom tune menu, so I can't fix this. Should they be there?
I have the Predator U7152. Serial: 200001d Rev: v.8r11 6/1/06
My vehicle is a 2004 Ford v10 gas E350 van customized to 4x4 by Sportsmobile.
Is there anything I can do but revert to the saved settings and not use my Predator on this vehicle? All I really want to do is override the top speed limiter (94 MPH).
-- Geoff
Geoff, I would assume you have taller than stock tires, correct?
Try adjusting the gear ratio up about 10% to make up for the speedo correction. (From 3.55>3.73 for example)
Let me know how this works out for you.
561-908-0040x4
Post Tue Jan 23, 2007 1:35 pm
That's the problem -- despite what the instructions say, my Predator does not have an "axle ratio" option. It's missing!
Post Tue Jan 23, 2007 3:47 pm
Ahhh, I see. I was unaware that this particular tool did not have adjustable parameters. There may be a fix in a future revision, but I do not have a fix in the works as of yet. Keep an eye on the home page of our website for info on revision releases.
561-908-0040x4
Return to Predator Ford Gas
