Board index (Legacy) Predator Technical Discussion Predator Ford Gas JLT91 running very lean espec. on throttle LTFT@17
please adjust the fuel or WOT. i added 5 to MAF because at default, it was idling bad
07092017jlt91.log
Data Viewer Log JLT91
(366.99 KiB) Downloaded 295 times
RXAP9N5_ORIG_07092017.frg
(852.25 KiB) Downloaded 291 times
RXAP9N5_JLTprem_07092017.frg
JLT 91 Octane Last written File
(5.25 KiB) Downloaded 299 times
is this the new JLT S3?
561-908-0040x4
i dont have a curve for the series 3 truck intake. but this should be close. load this in there and let me know
RXAP9N5_ser3jlt.frg
(852.14 KiB) Downloaded 296 times
Thank you will do tomorrow
Loaded it, sounds good but 2 codes P1000 OBD system readiness rest not complete
P2196 02 Sensor signal stuck rich bank 1
Lift both at
MAF
stay both above 25 to 28
In idle after 10 min warm up
sounds like a bad O2 sensor...
561-908-0040x4
But when I load the 91 JLT tune with +5 MAF it works okay. Just my short trim fuels are at 15 at idle. How so i adjust that? The file is above
Return to Predator Ford Gas
