custom tune question
wburners
Post by wburners »
2006 mustang gt slightly modified. I am having low idle issues. I have a custom tune loaded in the tuner now by T&S. I wanted to overwrite the custom tune with another and then reload it to see if it helps. I'm having trouble retrieving the org backup from my laptop. If I load one of the custom predator custom tunes already in the predator will I lose the custom tune or can I just reload the custom tune after the predator tune. I know If I put the org tune back in the tuner I lose the custom tune and have to download it which I can't do right now. Thanks for your help.
Re: custom tune question
Im afraid I am not following what you are asking exactly?
tech@diablosport.com
wburners
Post by wburners »
In the old predator uv7140 you cant have a custom tune and the factory tune in the predator at the same time. I cant get to my factory tune at present so I have a custom tune with the predator tunes loaded in the predator now. I'm having idle issues so I want to overwrite my custom tune and reload it. If I use a predator tune already in the tuner to overwrite the custom tune can I just reload the custom tune. without problems. Thanks
man, I guess I am still not following.
If you load a different custom tune to the tool, it will let you load that.
if you want to have more than one custom tune loaded to the device you can do that.
The backup/stock tune is always available to restore when needed.
