Board index General Technical Support MAF.i.a 2003 Lightning MAFia
MAF.i.a Support
Post Fri Oct 16, 2009 6:38 am
I have a K&N intake system, with a CycloneFuelSaver that fits perfectly into it, and a LFP Big Mouth Single Blade Throttle Body for my lightning. I found that the parts worked well together but it seemed like I was getting lag from my stock air flow sencer and it seemed it was not correcting it right...
I got the MAFia to hopefully correct the lag I was getting... I later found out it is mostly made for when you up the PSI boost past 10... I figered I would hook it in and put the stock setting in... and also try the 5 percent lean and 5 percent rich settings... figered why not...
I found that the lean setting seemed to work really well... The rich seemed almost heavy and the gas just seemed to sink as I hit the gas...
I found the the 5% lean seemed to work really well and even more power... I was looking up and reading some stuff on running lean. I found alot of people where saying that it over heats the engine and is hard on the parts inside...
I did test it at night in hawaii which is alot cooler then the day... but the lean seemed to work great...
I am wondering about damage... or if it was the parts that made it run well even though it was 5% lean... I am really mixed up on this...
Mike
Post Fri Oct 16, 2009 9:00 am
Ummm...what the heck is a cyclone fuel saver, and why did you not think to remove it first...it has NO place in a 380 HP supercharged performance truck.
561-908-0040x4
Post Fri Oct 16, 2009 4:56 pm
The Cyclone is just a piece that goes in the intake that spins the air... In theary... I figered it was free... for some reason it came in the truck when i bought it second hand... I put it in and then out... It actually seemed to make a little difference so I left it in... So if I took it out or left it in what do you think about my question...
Here is a link to the Website... if you wanted to look at the cyclone thing... I was on the fence many times of taking it out but you can feel a difference with it in... although not much...
http://secure.272.com/272/cyclone/qna.php
Mike
Post Fri Oct 16, 2009 5:06 pm
Well, I'd still say get rid of the gizmo, its prolly hurting more than it is helping.
Best bet here is to get the truck to a dyno and check the A/F at idle and at WOT to be sure all is well, the Mafia should not be used as a tuning aid, better to make actual adjustments to the tune throught the Predator.
561-908-0040x4
Post Fri Oct 16, 2009 5:34 pm
Thank you for the info... I was thinking the Predator is the way to go... I do have one other problem... I am in Hawaii on the main island and there is no Diablo Sports custom tunners... Do I just take to a place an Dyno tune anywhere... Get some help doing it...
Mike
Post Wed Oct 21, 2009 3:55 pm
You might want to try our dealer locator and if that doesn't get you anything I am sure one of our dealers here in the USA could email tune for you.
Kev
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: support@diablosport.com
Return to MAF.i.a
