2002 Ford 7.3 Diesel
RE: 2002 Ford 7.3 Diesel
BFG All Terrain TA KO...i have to get the cables to connect predator to computer so it won't be until monday (maybe today) when i can send the original backup to you. i will down load the DS downloader today please forgive me if i ask more ? later to transfer the files, computer skills a little rusty. will i still be able to use programer(once i send original) might have to go to arizona next week to haul back 20ft trailer..the intake on my truck is the conversion kit for a 6.0 im sure if you need any other info you will let me know.
2002 7.3 F-250 4x4 3.5 Dwn pipe 4" exhaust (Magnaflow) predator
yea you can use the programmer after you sent me it and yea its all good, once you get the cables let me know and well get it figured out.
Don
2002 WS6
2002 WS6
had time to run and get them today i know were on a 3 hrs time diffrence so ready when you are
Install all the drivers for the usb cable and have downloaded DSdownloader. Is a tune on the truck currently? If so connect the predator to the pc and open dsdownloader, it should find the tool then send you to a screen that says "get tune from tool", "sent tune to tool" etc. Hit get tune from tool it will say it is going to get the original backup off the tool, say yes and let it download. Then take that and send me it in an email.
Don
2002 WS6
2002 WS6
had to send through my e-mail not setup for outlook hope it worked
did you get the e-mail
No can you send it again?..what was the name on the email btw?
Don
2002 WS6
2002 WS6
the name on the e-mail is chris&mandy springer. sent .... let me know
got it is this just one ture? or multiple. either way what should i see as far as performane and mpg rough estimate is ok. is the tune (s) written for specs. tires, gear ratio, ect i gave you.
i transfered the file and downloaded it to tool message said it was identical to original file?
Its alittle different then your typical tune found on the tool, timing and fuel are changed a good deal from what is found on the tool, should also help with the laggy pedal feel a bit. When you load it to the tool, it will ask you for an original backup, select diablo.frg as your tune and your original backup.frg as your original file. I did include the tire size and gear ratio into the tune.
Don
2002 WS6
2002 WS6
ok.. i'll run it for a couple of days and get back to you thanks again for all of your help
