2002 Ford 7.3 Diesel
SCGt94
RE: 2002 Ford 7.3 Diesel
Post by SCGt94 »
no problem
Don
2002 WS6
springer
Post by springer »
so..loaded program in to truck vehicle becamre a crank no start. put 110hp program back on no problems. have you seen this?
2002 7.3 F-250 4x4 3.5 Dwn pipe 4" exhaust (Magnaflow) predator
SCGt94
Post by SCGt94 »
really? hmm thats odd, send me the last tune i sent you back, i wanna check something out.
Don
2002 WS6
springer
Post by springer »
sent it to you this morning sorry took so lomg
springer
Post by springer »
so.....just wondering did you get the files i sent
springer
Post by springer »
did don get fired or go on vacation?
SCGt94
Post by SCGt94 »
springer i think i sent you the files back didn't i?
Don
2002 WS6
springer
Post by springer »
yes got them, i still need to send you the tow tune to figure out this crank no start problem.
beefcake.
Post by beefcake. »
loaded my tune for a 2002 last night and getting the same code. my truck didn't come from anywhere near cal but who knows. i'm gonna try loading the other tune and see if it comes on
2002 7.3L F250 Crew 4x4
2011 5.0 Mustang GT - 10.81@128.6
beefcake.
Post by beefcake. »
well, i switchedto the tow tune, haven't tried the higher power one, but the tow tune showed no codes. i went wot 3 different times and nothing. the 85 throws everytime i start the car.
beefcake.
Re: RE: 2002 Ford 7.3 Diesel
Post by beefcake. »
beefcake. wrote:well, i switchedto the tow tune, haven't tried the higher power one, but the tow tune showed no codes. i went wot 3 different times and nothing. the 85 throws everytime i start the car.
so this morning, i loaded the 110 tune. right before work, went to my spot, did a wot blast. And after about 80 percent throttle I got some killer injector shake, backed off tried again, same thing.
My point though. Their were no codes with the 110 tune, even jumping around like it did. No codes on the tow tune, but the 85 tune starts throwing the 1211 almost instantly.
tuningss
RE: Re: RE: 2002 Ford 7.3 Diesel
Post by tuningss »
Use the DSDL to export the 110 tune, load the 85 tune and export it, then export the original backup and post them here. I will take a look.
http://www.tpctuning.com
beefcake.
Re: RE: Re: RE: 2002 Ford 7.3 Diesel
Post by beefcake. »
tuningss wrote:Use the DSDL to export the 110 tune, load the 85 tune and export it, then export the original backup and post them here. I will take a look.
Silly question, but how to I get the tune to the computer?
I'm assuming i need to buy a cable of some sort. It's a little frustrating. I've always used xcals in the past that come with a usb that plugs right into it.
the predator isn't making it easy to get the tune?
do i have to by the cable from diablo or is this something i can go to best buy or somewhere and get................................................
tuningss
RE: Re: RE: Re: RE: 2002 Ford 7.3 Diesel
Post by tuningss »
Just a USB to serial cable and a laptop works fine. Power the unit with the vehicle, use the DSDL software and export both the tunes.
beefcake.
Post by beefcake. »
uploaded stock and the 3 tunes that came on the predator. again, the 85 sets the 1211 instantly. 2 different times, it said a wastegate performance as well. not sure what that was.
is it possible to remove all shift pressure increase from all the tunes, so i don't have to worry about it.
lastly, the 110, i've tried some wots a couple times with it the last few days, in 2nd and 3rd gear, i don't get the injector shake that i get in first gear, but that last 10-15% throttle the engine sound is definately "louder" not sure if that's normal on the 110 tune or not or if it should be tweaked. didn't know if i should have a degree of wot timing pulled?? i don't know enough about these to know what i'm listening to, to be honest. maybe it's fine how it is? maybe a degree in 1st gear. who knows, lol.
again, codes only on the 85
tnaa7w3.frg
stock file
(224.25 KiB) Downloaded 259 times
tnaa7w3_custom110.frg
110 tune
(5.25 KiB) Downloaded 277 times
tnaa7w3_custom85.frg
85 tune
(6.25 KiB) Downloaded 273 times
tnaa7w3_customtow.frg
tow
(6.25 KiB) Downloaded 259 times
