Board index Trinity Technical Discussion Trinity Ford Gas Calculating tire size
Post Tue Feb 02, 2010 4:45 pm
http://www.gordon-glasgow.org/tirecalc.html
or, use this handy tire revs per mile calculator:
Tire_Conversion_Revs.xls
(25 KiB) Downloaded 1018 times
561-908-0040x4
Post Sun Feb 14, 2010 11:15 am
I run staggered tire sizes; I assume I should use the tire size info from my rear tires for this calculation...am I correct? :punisher:
-Chris
Post Sun Feb 14, 2010 2:41 pm
Yes, the rear tires are the ones you use.
http://www.tpctuning.com
Post Sun Mar 13, 2011 8:23 pm
There are all kinds of apps for smart phones too..
Post Sun Apr 17, 2011 10:30 am
thank you!!!
Post Wed Jan 11, 2012 3:30 pm
These calculations will get you in the ballpark. However, it has been my experience that your speedometer will be off by about 5 mph @ 80mph. I used my GPS to help me fine tune the value for the revs per mile in the tune. I ended up having to use a value of 880 revs per mile for a set of 275/40 R18 wheels. If you run this through your calculations it will tell you that you should be running 756 for the revs per mile.
Post Wed Oct 08, 2014 7:42 am
I'm trying to do the tire Change on my truck and was wondering do I put in the revs per mile in the tire circumference? I'm running a 35x12.50x20.
Post Wed Mar 11, 2015 9:03 pm
sup bruh ,im tried to recalibrate my speedo but it asked for diameter and mine says is 100.25 for a set of 275/55/20 lowest value is 500 what im doing wrong :normal:
Return to Trinity Ford Gas
