Board index (Legacy) Predator Technical Discussion Predator GM Gas Logging Parameters locations in sub-menus
Moderators: mikel, 06MonteSS
In the Trinity and new revision 7194 Predators, the logging/monitoring parameter listings are now all under different sub-menus.
This guide below can be used to locate the necessary parameters needed to log for a custom tune...
Air Fuel Ratio (Equivalence Ratio) = Under FUEL menu
Long Term fuel trim bank 1 = under FUEL menu
Long Term Fuel Trim Bank 2 = under FUEL menu
Spark Advance = under IGNITION menu
Intake air Temp = under INTAKE menu
MAF Sensor Mass Air Flow = under INTAKE menu
Total Knock Spark Retard =under MISFIRE menu
Engine Speed (RPM) = under PERFORMANCE menu
Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
NICE!! thanks man!!!!
woohoo!!!
this will make it SOOOO much easier for Predator/Trinity users now that they'll be able to find all the parameters and not have to search for hours... :lol:
no..........Thank you Lew for everything. I know this will take some headaches from you...
aviraled, your a saint. :mrgreen:
"The Speed Demon"
Awww...glad it helped!
Nice had to save ' will save me a lot of headache. Thanks
2010 SS/RS COLD AIR INDUCTIONS CAI, PREDATOR U7194, 160 STAT,MSD WIRES,BILLET ACC. CAPS,
ARH 1/78 LONG TUBE HEADERS W/ CATTED X-PIPE AND SLP AXLE BACK
you just saved me about an hour. THANKS!
BONE STOCK (so far)
2010 SIlverado Reg. Cab Long Box
Floor Shift 4x4, 3.42's
4.8 V8
U7194 9r16
I WANT TCM CONTROL!
Return to Predator GM Gas
cron
