Board index (Legacy) Predator Technical Discussion Predator Ford Gas Legacy Connect/"Appliction is Missing or Corrupt"
Revision Update Instructions- Using Legacy Connect
[b]Some older versions of Predator software cannot be auto detected by the DS Downloader. Any tool with a revision starting with 7rxx and some older 8rxx revisions will fall into this category. Any tool with a 9rxx revision will auto connect, and should not require legacy connection (but it can still be utilized if you desire). If your tool requires Legacy connection, follow these steps. Also for use if your tool displays “Application is Missing or Corruptâ€
Revision Update Instructions- Legacy.docx
Download as Word File
(20.97 KiB) Downloaded 1090 times
Return to Predator Ford Gas
