Did you know...
Did you know...
That the latest version of DSDL allows you to upload/download Trinity dashes?
Using the Trinity manager tab at the bottom of DSDL 2219, you can upload dashes from the Trinity to the PC or download dashes from the PC to the Trinity.
For some reason, the SRT4 applications use the HEMI layouts, so hers a couple SRT4 layouts for U7134 users:
Open dsdl, let it find the trinity, click the Trinity Browser button.
Click 'refresh'.
It will show a list of all part numbers, click on 7134, and click 'Put'.
Browse for one of these layouts, and select it, DSDL will load it into your Trinity.
Load 1 at a time until you are done and then when you go to the monitoring or logging menu, both of these layouts will appear.
SRT_4.TDS
(642 Bytes) Downloaded 1053 times
SRT_4_2.TDS
(554 Bytes) Downloaded 1210 times
tech@diablosport.com
ColdfusionDesigns
RE: Did you know...
Post by ColdfusionDesigns »
Tried to "Put" But it didnt upload to my Trinity. My others will upload fine but not these one and only these. :/ oh well. I just wanted to see the layout you guys had.
Zoban
RE: Did you know...
Post by Zoban »
Had issues putting files with the DSDL too .. It worked importing from the SD card though..
gizmodo
RE: Did you know...
Post by gizmodo »
Those two are already in the 1r08aa crom.
jaelliott
Re: Did you know...
Post by jaelliott »
I am either not understanding correctly or am missing something in the process. I want to take Johans recommended PID list 07-up and make a dash of it for logging. The problem I come across is the dataviewer dashboard is a .dsh file and the trinity layout is a .tds. I tried uploading it anyway but have had no luck so far. I even tried renaming the .dsh file extension to .tds and see if I could "trick" it. The dash does not show up in the list of layouts on my Trinity.
AZlxsrt
Re: Did you know...
Post by AZlxsrt »
what exactly does this do?
