Board index (Legacy) Predator Technical Discussion Predator Ford Diesel Breakdown of logging parameters?
Post Tue Jan 11, 2011 10:09 pm
I saw that there were a lot of parameters. I don't have any gauges, so with the new tune, i'd like to see a couple things.
Trans temp, which i think i found,
Boost - wondering if thats in there? i found a few manifold places logs, not sure if one of those is boost.
Would also like maybe injector duty to see make sure i'm okat there as well.
Anything else that would be recommend to look at?
i'm assuming there is no EGT / Pyro
Also, I get the 1211 Injector Control Module pressure to high or low, would like to log that too, just to see where it's at
2002 7.3L F250 Crew 4x4
2011 5.0 Mustang GT - 10.81@128.6
Post Wed Jan 12, 2011 10:24 am
it's snowy out, and roads were crowded, so i couldn't get on it a ton, but i put it in 4wd and hit it on the back stretch of the dealership.
it's cool out 15 degrees or so.
I did one little wot blast going halfway through second
trans temp was about 110 degrees
inj pressure (i guess this is where the 1211 code comes from?) was 17, i believe mpa?
i did 2 manifold pressures, one was absolute manifold pressure and the other was manifold gauge pressure
during lite throttle driving, the abs mp would stay around the low 100's and the manifold gauge pressure would stay about 10% of that roughly
140kpa/13kpa
at wot, the abs mp went to about 240kpa and the manifold gp went to 140kpa
anyone able to break the info down? to be honest, i'm not sure what i'm looking at on this thing, lol
Post Wed Jan 12, 2011 10:37 am
I found a kpa to psi conversion
1 Kpa (Kilopascal) = 0.145037738 Psi (Pound Per Square Inch)
So i'm assuming the manifold pressure would be my actual boost.
144 x .145037738= 20.88 psi.
Sound about right for an 85hp tune?
Is there a way to convert in the logger to psi instead of kpa?
Post Wed Jan 12, 2011 12:55 pm
you can convert any gauge showing kpa to psi.
logging/create a new log/from an existing layout/choose the layout
click on the boost gauge, choose 'change display units', choose PSi, then save and rename the layout. It will now show PSI when you open it in monitoring, same goes for KPH to MPH, and a few other conversions.
561-908-0040x4
Post Wed Jan 12, 2011 1:03 pm
sweet, thanks
Post Wed Jan 12, 2011 9:38 pm
so, i hooked up the predator to the obdii again, couldn't find what you were talking about. how do i get there. didn't see any parameters
Damn, my bad, I was in Trinity mode when I answered that, it is not something you can do in the Predator, sorry.
561-908-0040x4
Return to Predator Ford Diesel
