Board index General Technical Support MAF.i.a technical question about maf on supercharger car
MAF.i.a Support
Hi!!!, I got a 2008 mustang gt supercharged (Prorcharger stage II HO).
I have 3 question:
1) My procharger kit include a predator PC7140 with a procharger tune (stage II HO), my question is: with this tune can i use a MAF.i.a? or i have to a custom tune for that?
2) the MAF.i.a can only be used if my car is pegging at 5V (maf)?
3) Example: if my voltage if a 4.2 V at 5500 rpm, if everything fine?
Thanks so much!!!
:D
1. That tune should be set up for the Mafia if it came with the kit, i would contact procharger for clairification.
2. Thats what it is designed for, yes.
3. No, because if you rev to 6000+ it will be closer to 5V.
561-908-0040x4
Post Thu Jun 02, 2011 10:54 am
thanks mike for your quick response,
abouth this: (3) Example: if my voltage if a 4.2 V at 5500 rpm, if everything fine? )
My car at 6000 rpm has 4.3 v, how i can increase it to be around 5v?
Thanks!
Post Thu Jun 02, 2011 11:09 am
You do not want to increase it....if you get to 5V you have problems ;)
561-908-0040x4
Return to MAF.i.a
