Board index (Legacy) Predator Technical Discussion Predator Ford Gas 05-up Ford (U7140/U7141/U7145/U7151) custom tune instruction
2. v.8r22
3. 2006, Mustang Gt, ford
HELP!!HELP!!HELP!!
i programmed the 91 octane and accidentally hit factory hp tune. then i unplugged it and now it wont start. and when it does the gas doesnt work. i programmed it back to 87 octane and restored original back up and it still wont start and the gas wont work. how do i fix it?
Rear wheel horsepower can be measured on a dyno. Flywheel horsepower can only be measured by pulling the engine out of the car completely and testing it on the bench. There is no general RWHP = FWHP * 0.86 equation to apply to your question. With every car the loss due to drivetrain is going to be different, because every car is different. All that we can tell you is what a car very similar to yours had at the rear wheel before and after it was tuned.
diablo 3 guide diablo 3 guide diablo 3 guide
juangonzales wrote:
i have a problem with uplaoding a custom tune to my diablo tuner .it says device not located or not communicating with tool? can you help i went through the installation instructions
sounds like the driver for the usb to serial cable is not working.
561-908-0040x4
I wasn't sure how to go about submitting for a custom tune, so I thought I would try this... sorry if it's not the way to do it.
I have a 2007 Mustang GT 4.6L 3V. I have the Predator Tuner (U7145). The bolt on power adders I have are:
BBK Twin 62mm Throttle Body
K&N CAI
SR Underdrive Pulleys
Flowmaster Exhaust (Not sure which series, it was on when I bought the car - used).
I use only Premium fuel, the highest that particular gas station has (91, 92...). I currently have the 93 Octane/K&N CAI tune loaded in the car. Any suggestions? Incidentally, after installing the BBK TB, I must not have gotten it set perfectly, because at idle, the RPM's bounce about 50-100RPM. Can that be fixed through a program, or do I need to re-set the TB?
Looking forward to the response.
Thank you!
can i get a custom 91 octane tune? i am running a JLT series 3 intake along w/ comp cams stage 2 mutha tumprs.
7mm
does a u7141 work on an 09 mustang gt ?
No, 2010 only.
561-908-0040x4
7mm
OK. I have a u7141 up for sale..150$ unlocked ready to go
i have a u7145 that works for 07 and 05 apparently will it work on my 06 ?
Hi my name is Michael Martin. I bought a 2007 Mustang with a 2005 5.4 Motor in it(f150). It has a Diablo tuner but gentleman I bought from said he tuned it down. The car has a Edelbrock E Force Supercharger on it. I got the Edelbrock cold air intake for it ready to go on. Its Auto with Outlaw TCI Rachet shifter, 4.10 rear end, posi, rebuilt transmission. Want to put new tune on it and need help. Right now has original tune in it. Tried Diablo tune on there and it runs worse. Please help been going crazy trying to have someone help me but no luck. Should of came here long tome ago. I haven't done nothing other than try 2 tunes on it and original seems to run better. I want to put my Edelbrock Cold Air intake on and re tube so it runs to its potential. Please help I see you closed today and will call Monday if I have to but hoping I can get this taking care of. Speedometer not right tire sizes are Mickey Thompsons rears are 30x12.00x18lt fronts are 28x10.00x18lt. Im want to get this done just want the right tune to down load. Hope all is well with you and family. I am Quarantined being im a type 1 diabetic all I can do is drive my car and want it running right. Aggravating. Can give you any more info you need. Thank you in advance and God Bless. P.S has 85mm throttle body and new mass air flow sensor for Edelbrock Cold Air Intake
Previous
Return to Predator Ford Gas
