2003 GMC Sierra electric fan swap
I have a 2003 GMC Sierra 2500. I installed 05 electric fans and am using a switch in the heater hose. I'd like to have the pcm activate the fans like factory 05's. I'm using a predator U7193. Can you help me?
Shootin for the moon
Re: 2003 GMC Sierra electric fan swap
Here's my tune files if you get a chance.
- ar12579405cua.grg
- (312.11 KiB) Downloaded 344 times
- AR12579405CUA_custom.grg
- (6.25 KiB) Downloaded 365 times
Just curious if anyone has given this a look
not sure how i missed this, but here you go, sorry for the delay.
- ar12579405cua_fans.grg
- (248.1 KiB) Downloaded 367 times
tech@diablosport.com
Thank you very much. I figured you guys were probably busy.
I haven't used the predator in a while. When I plugged it into my truck, it powered up, let me select the custom tune, and then said "The tune file was not installed to vehicle, error (). It's got me baffled. I send the files from the computer to the tool first.
got a stereo installed?
anything thats been installed since last time you flashed it?
I had an aftermarket in it before, but I have replace it with a new one a month ago.
My volt meter is reading at the line between 9 and 14. Do you think the voltage is too low?
I just remember I installed a remote start after I flashed it.
its somethign wired into the trucks harness causing the issue.
if there is a stereo, its the aftermarket adapter harness, unplug that from the vehicle harness.
If remote start, disconnect it from the vehicle harness.
It was the remote start. I unhooked it and the tune loaded perfectly. Thanks for the help, I really really appreciate it.
sweeeet.
I forgot my remote start hooks up to the datalink in the obd2 port. That probably didn't help anything.
