2014 gt500 jlt tune?
I have a 2014 gt500 and the trinity t1000 tuner. I just bought a jlt 148mm maf intake and I was wondering if the jlt tune for the trinity t1000 works with this intake? if not, what size maf is the tune for?
Re: 2014 gt500 jlt tune?
WE used the carbon 127mm which was the only one available at the time. If you load the current JLT tune and then get me a log of idle at running temp I'll adjust it for you and you'll be good.
Insert Clever comment here...
do you have one 127 mm tune for my 2012.....and mine is intune ....sorry my por English...
Post your last tune written.
thank my friend
when making a post go down to upload attachment and then browse adn then select the file from the tool. If youre asking about getting the file from the tool use dsdownloader and hit get tune file from tool and then select last tune written and original backup.
thank for the explication very helpfull..thank...Benoit
Here you go. When loading this make sure you select this file first and when it asks you for the second file that you select the original backup otherwise it will not load right.
- pcm_fgdh3s3_JLT127mm.frg
- (523.08 KiB) Downloaded 301 times
SOHFAST94....you or the Men......am very Happy..............Benoit
sohfast.......thank..
where did the other 2 come from?
just use the one he posted here.
tech@diablosport.com
my fault...so mikel this jlt127mm work well whit my mod...12 psi and 93 octane......thank
